Starter issue
I have a 1986 740 GLE wagon and every once-in-awhile when i try and start it the starter clicks and doesn’t turn the motor. When this happens I turn the motor by hand then I turn the key the car starts. Usually when I turn the key the car starts right up. Is that a sign of a bad starter |
Originally Posted by Ross Miner
(Post 471509)
I charged the battery about a month ago. The clicking started recently. Where is the starter located |
(Post 471516)
you could also check/clean ground wire coming from negative terminal on battery.
(Post 471516)
Most likely you have a bad starter that needs to be changed... $60+ an hr labor.
