-   Volvo 240, 740 & 940 (https://volvoforums.com/forum/volvo-240-740-940-12/)
-   -   Sun Roof problem (https://volvoforums.com/forum/volvo-240-740-940-12/sun-roof-problem-10312/)
lotusing Feb 28, 2007 06:48 PM
Sun Roof problem
Hello all,
My sunroof is not working but luck for me I have a parts car.Anyway, when I hit the switch it just clicks.I thought it was the motor so I used the other motor that I know works.It does the same thing.Well I tried opening it manually a bit and then the roof opens with the button but now will not close.I when to the dealer and they said to take out the motor and cycle it without it connected,it turn a little than stopped.What could be wrong?
Yves666 Mar 28, 2007 09:42 PM
RE: Sun Roof problem
hey i bought an used 940 one hour ago and I have the same problem!?
how can I close the damn roof again?
I dont have the money to see the dealer just because of this (little) problem!
if some one know how to fix it I would really appretiate to hear from you!
thanxs all
yves
Mars Mar 29, 2007 03:09 AM
Pop open that cover by the review mirror and inside you will see a place you can put a flat head screw driver in a slot that you can manually crank the sun roof with.
Mars Mar 29, 2007 03:10 AM
ORIGINAL: lotusing
Hello all,
Look a long the track and see if its held up on anything. I had that exact issue on one of my 940's
