Supernatural alternator problem
re '86 DL 240 wagon here. The alternator either died or started dying almost two months ago and I sought advice here. A few brave souls responded with a lot of useful information but get this; I've been through two remanufactured and one new alternator and still haven't fixed the problem. I've learned a lot about alternators and my wiring system in that time. I've checked all grounds. Re-routed the D+ wire from alt to firewall junction box. The alt warning light does go on in key position 2 and goes off when the engine starts running and the alternator starts spinning - (light goes off even when engine starts and alt isNOT charging. Is this a clue? ) but still no charge.
On rebuild #2 I got a slow climb to 14 volts but then it stopped charging. When I tested the diodes on that alternator - while it was sill hot from spinning, I got the reading of bad diodes. So I got a new alternator but got nothing. All of these alternators were Auto Zone and I had them checked after they did not work on their test equipment which said the alternators did work. I went to a competing parts store and had them test the last alt and it scored positive - but would not charge my battery. I did a parasitic draw test on the fuses and discovered the radio - which has never worked and only made squaks - was drawing energy from the battery so I disconnected it completely from the car.
So - now I'm tracing the D+ Circuit from alt to junction box at firewal (A in diagram) , to
[IMG]file://localhost/Users/dagaan/Library/Caches/TemporaryItems/msoclip/0clip_image002.png[/IMG]
to battery charge warning light, to fuse 13 and out fuse 12 to key to key to whatever that box with four dots between the key and the battery + - to make sure this circuit is running ok. I'd like to know authoritatively what the Volt reading is on the D+ post on alt so that I can see the same voltage all through the circuit. Someone said it should be between 7 and 9 volts. But mine so far has read exactly the charge of the battery on both alt posts (B+ and D+) tho once it read .54 Volts. With key in position 2, I get no continuity on fuse 4 for the in tank fuel pump. Is this normal? I'll test the in tank pump to see if it is working but after that I don't know what to do. I've been banned from Auto Zone - they gave me a full refund and more or less said don't come back! The alternator circuit is pretty simple. Why is this happening?
Yes this is the famous '86 edition with the biodegradable wiring. Yes it causes all kinds of problems. I already know that. What I need to know is how to make the wiring circuit outside the harness. The wire from the D+ post of the alt is good once inside the harness - after that wiring is mostly internal (not exposed to melting elements) - wire from D+ to warning light - to fuse - then not sure - back to battery + post? If I rebuild the circuit it should work?
the D+ wire goes from the ignition key to the ALT lamp in the dashboard to the D+ terminal on the alternator. period.
the B+ lead of the alternator is connected to the big stud on the starter motor, and that in turn is connected to the battery+ via the big heavy cable.
when you turn the key on there should be a voltage (less than 12V, probably somewhere from 5-9V?) on the D+ terminal of the alternator relative to ground.
when the engine is running, the B+ terminal of the alternator should be around 14V relative to alternator ground. B+ and battery + should be identical. alternator ground should be 0V relative to battery -
Pierce - Since the wire from the D+ post on alt basically feeds back to the + post on the battery - shouldn't it be possible to connect the D+ straight to the battery, bypassing the warning light and key - and get 14 volts? This to prove the alternator is charging regardless of the circuit. I did this on the last alternator and got nothing.
Make sure that the ground wire for the alternator has zero ohms.Set meter to ohms. touch one lead to alternator body. one lead to ground on body. Meter should read zero. If not after disconnecting battery remove ground from alternator. Remove ground connection from block. Measure wire as to ohms. Clean both ends up, clean block mounting area. fasten to block. check ohms. fasten to alternator . check again.
That's what got me.
That's what got me.
That's what got me.
That's what got me.
davesee1
09-24-2010 05:49 AM
