Tail light assembly replaced
I replaced my tail light assembly on 1992 740 wagon and now I notice that the 3rd bake light comes on with the running lights and stays on but gets brighter when i apply brake pedal is this normal or do I have open ground some where any advice appreciated
Charles
Charles
I would bet on a bad ground to a tail lamp if the 3rd brake glows dim with parking lamps and there is a 1157 dual filament bulb in one of the lenses. (can't remember if there is a dual function bulb in one of those.) If so a bad ground will cause current to back feed through the brake bulbs. Take the 3rd brake light (and probably the brake bulb on the other side) and watch the parking lights not work (I guess you are just having a problem on one side)
Lars Petrey
05-30-2021 08:56 AM
