Temp. Compensation Board
How do you bypass the temperature compensationboard and in doing so will the temp guage still work?
RE: Temp. Compensation Board
Fantastic, thanks a lot...
If you don't want to do the soldering, you can buy a push-on jumper wire. IPD sells them for about $15. Go to www.ipdusa.com. And yes, the temp gauge will work after you install the jumper (assuming the gauge is good), the needle just won't stay in the middle like it does with the non-jumped compensation board.
