timing belt b230
Is it crucial to use the special tool or to block the flywheel in order to change the timing belt on the B230? I plan to use an impact gun on the crank pulley which I have heard will make it less important as the crank will be less likely to move. This will be the final phase of the resurrection of my 91 244, I hope. Thanks!!
RE: timing belt b230
No you don't have to hold the crank to replace the belt.Just make sure it is lined up before installing the belt.
I bought the tool.
They are great while removing the balancer aren't they.
| All times are GMT -5. The time now is 12:57 AM. |
