Transmission Fluid Change
My 1993 940 Turbo has 161,000 miles. The transmission fluid is dirty, and it was suggested that I change it. I have heard that changing the fluid can cause problems with the seals. Common sense tells me that if the fluid is dirty, then it should be changed. Appreciate any opinions.
Ken |
RE: Transmission Fluid Change
changin it is a good idea, but make sure to put a new filter in also. ive herd that its not good to flush the transmision it may cause further problems.
