Turbo to NA conversion
Any tips on converting a 940 turbo to NA head?
Same 530 head; different cam; same ECU; just plumbing? Thanks |
why you want to do that?
sell yours and buy a NA one. Just switch exhaust manifolds/ header pipe. then remove intake plumbing. find NA ECU/ICU. etc. the opposite of +T. The 530 head is the same on the NA....well. it should be. |
Why do you want to remove the turbo? If it's had it, just replace the turbo or rebuild it. There is nothing mystical about rebuilding a turbo unless parts are broken.
Regards, Andrew. |
When we had our turbo replaced a few years back, my mom thought that might be a cheaper thing to do. Just take it off. The conclusion was, if you did it right, you would get a pretty sluggish car. If you messed up, it would be a really sluggish car. One thing to keep in mind, in an engine the intake and exhaust valves are open at the same time for a little amount of time between the exhaust and intake strokes. This allows the last bits of exhaust gas to exit while new fresh charge comes in to replace it. In a turbo charged motor, this overlapping time can be shorter because something is pumping the new charge in and the exhaust out during this time. This requires different camshafts. Now I don't know if Volvo put different camshafts in turbo/nonturbo motors, but my point is there might be a lot of unexpected differences that will ultimately lead to a relatively untuned "de-turbocharged" motor rather than a naturally aspirated motor.
I believe they used the T grind cam in most.... I thought the only difference in the heads where the Turbo models had sodium filled exhaust valve.
