Volvo 240 Leaking Water
Hows it going !
I recently picked up a volvo 240 automatic transmission. After driving it for about 30 miles. I noticed a water leak from the line that goes to the oil pan. I am not too familiar with these cars yet. I came from owning a BMW e30. Everything is foreign to me at the moment. The water leaks a good amount after driving it. i am not too sure if it is engine oil or trans fluid leaking. I am hoping someone can lead in me in the right direction. thank u |
Is it water, or oil or ATF? No line goes to the oil pan, cooling lines go to the transmission pan as does the filler neck line which often leaks. Lift the car and look under it to see what's going on.
