sticky automatic transmission shifter button
Hi pierse
I'm looking for a diagram for a 1988 volvo 740 auto shifter... Like a factory diagram... I'd like to order some parts for mine and I think a diagram would help a lot.
I'm having to press down on the shift button while turning the ignition key to start the car... I have to wiggle the shifter at the same time too...
I replaced the Neutral safety switch.. I'm not sure what could be creating the problem... Any help would be appreciated...
its pretty similar.
https://lh6.googleusercontent.com/-k...612%2520PM.jpg
per your symptoms, I suspect what you will have to do is, take it apart and figure out whats worn out. my guess is, the bushings that the shift lever pivots on, like 7 and 17 in that drawing. I believe to completely disassemble it, you'll need to go under the car, and disconnect the shift rods 22 and 26 via shafts #10, then the whole shifter assembly including the cup 5/6 its in should lift out so you can further disassemble it.
schmuecker
05-19-2011 06:45 PM
