water draining out of back pipe; 1985 240
All, I have a 1985 240 and have noticed that when parked, water will drain out of a pipe in the back, on the driver's side under the trunk. Any idea where this is coming from and why?
Thank you, Susan |
Go into the trunk and pull the spare tire out and see if you have water under it. If so there is a rubber drain plug that needs to be cleaned and checked.
Originally Posted by jagtoes
(Post 264862)
Amelia240, how much water is coming out of that pipe? Is it a metal pipe that's about 2 inch diameter? It almost sounds like you are describing the tailpipe. |
