Which way does coolant flow?
Old Jul 18, 2006 | 12:21 AM
heyma's Avatar
Default Which way does coolant flow?
Hi:
Does the coolant flow FROM the thermostat, into the top of the radiator, out the bottom of the radiator, and into the waterpump? Or vice versa?
Thanks.
Old Jul 18, 2006 | 12:39 AM
Default RE: Which way does coolant flow?
It should flow from the upper hose into the Block through the thermostat. Then through the water pump to the Radiator.
Old Jul 18, 2006 | 12:55 AM
heyma's Avatar
So if the upper radiator hose is hot, then it means the thermostat is NOT opening? Or do I have it wrong?
Old Jul 18, 2006 | 11:56 AM
cbevis's Avatar
The hose coming from the thermostat to the botom of the radiator should be warm if the thermostat is working.
Old Jul 18, 2006 | 12:58 PM
heyma's Avatar
On this 740, this is the coolant system setup:
Thermostat in housing at top of engine - hose to top of radiator - hose from bottom of radiator to waterpump
When I felt the hose between the thermostat and top of the radiator, it was hot. If the coolant should ENTER the engine from this hose based on what Tech said, then this hose should be cool, right? If not, is the thermostat not working?
Old Jul 18, 2006 | 02:11 PM
cbevis's Avatar
well...cool relative to the rest of the enginge...190 some degrees F is still pretty hot to the touch.
Sorry 'bout that earlier post...i was confusing my cavalier and the volvo again.....
However, if all the hoses are hot off the thermostat (regardless of where they go) then it's working. Weather or not it's working properly on the other hand is another question. Are you overheating?
Old Jul 19, 2006 | 12:18 AM
If your upper Hose is really hot and the Bottom hose is cold then the thermostat is not working properly.
grndslm
May 14, 2017 02:54 PM
Shel1555
Jun 6, 2012 08:54 PM
2001s602.4t
Jul 23, 2011 11:22 AM
Ahmed
Aug 30, 2009 01:58 PM
AustinPower
Dec 15, 2006 02:59 AM
