Wiper Pump Ground .... Solution?
The wiper pump doesn't work in my '83 240 Wagon.
Thought I'd remove it and scope things out. I removed the collant expansion tank, so I could then remove the wiper tank. I only needed to move the wiper fluid tankslightly up and out of the metal frame it sits in and, suddenly, the thing starts pumping water like mad. Trouble is this; as soon as I drop the tankback to it's proper position, it againwill not work. Looks like a ground problem. Any suggestions on how to remedy? Thanks. |
RE: Wiper Pump Ground .... Solution?
possible broken wire in the connector
| All times are GMT -5. The time now is 08:23 AM. |
