Would it matter?
I took the car for alignment today and they said that they couldnt do it because the strut mount was damaged, so one question, if i dont change this part, would there be a major damage?
RE: Would it matter?
It will just wear the tires out.
oh ok thanks, well the mechanic said that i should change both because they are old, only the right one is making the noise, but what do you say, should i change both or just the broken one?
If the cost is not so bad, you should better off changing both, this way you will save time and maybe in a couple of months you will end up changing the other.
Its better once for both, one labor charge for both instead of two separate charges. |
Hmm ok ty
I agree do both now.
Ok, i will do them both now, but first im taking the car for a diagnostic at the volvo tomorrow because the stupid mechanic doesnt know jack.
