1989 760 turbo
Car stalls out when driving down road. Does not matter what the speed it varies. Does not do it when parked at idle. When it stalls it will start back up after about two seconds, sometimes it just kicks back to running on its own. HELP very confused. Thanks
RE: 1989 760 turbo
could be a partially plugged fuel filter.
RE: 1989 760 turbo
For anyone that has had similar problem, here is what worked for me. The LUXOR injection amplifier ECU which is located on the drivers side inside fender well behind the battery. this is a very small relay that shuts down the injectors. This is the site that helped me http://www.carelect.demon.co.uk/vvp1d1.html GOOD LUCK.
