1992 960 wagon wiring diagrams
i just have a few questions, first, i need to know if someone can post a wiring diagram for the engine computer, and it needs to include the control wires that go to each coil, also, is it possible to remove an engine computer from a donor 960, same year and have it work in the one i have? thanks
ok well i found my motronics under driver side kick panel and i found a wiring diagram for a 94 960, im assuming its the same, and if it is, my question is this then, im working with checking for resistance for the circuit for cyl 5 coil, the diagram shows the wire going from the coil to something called a motronic 1 power stage (located at intake manifold) what is this, where is it and what does it do? its wired to 3 coils (theres another one for the other 3 coils) and also , which wire that is coming out of it will be the control for cyl 5?
