1992 Volvo 960, serious transmission issue
3 Attachment(s)
So i recently purchased a 1992 Volvo 960, RWD, 32 valve I6, some info/issues about the car:
- 164,000 kms - Very good condition with virtually no rust, absolutely no rot. - The Nivomat rear shocks are shot the the rear end sags ($1000 CANADIN to replace). - Parking break is broken. But, the main issue is the transmission. I get the flashing arrow and the flashing WSE switch and error code 2-3-2 for the transmission. its very sparatic(seems to only happen once the car is warmed up) but the transmission will slip so bad it seems to "let go" of the gear and shift itelf into neutral(slipping?). Also the car has a horrible time shifting and i usually need to put it into L then 3 then D to get it to get up to speed. I replaced the rear ABS/Speed sensor that is located in the rear Differential ($350 and, as per error code) wich made the car seem perfectly fixed for about two days but then when driving oin heavy snow on slippery roads the issue is back in full force. Does anybody have an idea of whats going on? Thanks. |
Welcome to the forum Snowy :D
Moved to 960 forum |
wonder if this is the same issue i have just started having with my 96......i just ordered a new PNS switch to see if that fixes the issue
