95 960 wagon - windshield wiper pump
My rear washer pump failed years ago (no big deal) but now the reservoir has developed a leak but it still maintains enough fluid to get by. At any rate it's time to remove the reservoir and fix both issues. Can't figure out an easy way to remove the darn thing.
It's located on the drivers side of the vehicle underneath the air filter housing - removed the air filter but couldn't figure out how to remove the housing. Probably an easier way to address the issue. Any help appreciated. Kevin |
it pops right out after u remove the airfilter. wasnt that bad.... :)
Thanks for the reply but this isn't "popping out" after removal of the air filter. The air housing is tied to fire wall with two connectors and other stuff located on the other side. I have read similar responses on other forums but I suspect those are for other models/years - I have a 95 960 wagon. Maybe there is something I am missing to get mine to "pop out" but once I remove the stuff holding it to the fire wall it seem the only thing holding it in place aren't underneath but part of the assembly located on the other side of the air housing. Maybe I am missing something obvious - won't be the first time.
