'95 960 will not restart after running for a few minutes.
Old Nov 29, 2022 | 06:32 PM
Chuxpix's Avatar
Default '95 960 will not restart after running for a few minutes.
A little background... two years ago my timing belt in my 95 960 wagon detonated and bent all 24 valves. I eventually found a great running 960 engine from a 96 model and had it installed. It starts cold and runs great - till I shut it off and try to restart it. It still has some old gas in it and it smells like it is flooding when I try to restart it. If I leave it set for an hour or so it will start right up and run fine - until I shut it off again.
I know little to nothing about fuel injection but suspect a fuel pressure problem. Has anybody else had experience with this and what did you do to fix it?
Old Dec 8, 2022 | 11:50 AM
Cubic_Curiosity's Avatar
Been here, done that with our '95 ;o)
Here's what might be happening: The injectors dribble on these cars after shutdown when they get older.
Just check for a raw fuel smell inside the intake boot after things have been shut down for a bit. If it reeks, one or more of the injectors might need to be replaced...
Old Dec 8, 2022 | 03:50 PM
If your car has the same orange Bosch injectors as the 850s, PM me - I have a set of five that I can send you. (no more 850 so no need for the parts).
willietopz
May 21, 2014 10:32 AM
Milasin77
Feb 20, 2013 04:47 PM
pepes960
Oct 30, 2010 08:17 PM
downloader
Apr 20, 2008 06:51 AM
waxk
Feb 9, 2004 11:46 PM
