"96 960 rear transverse spring mounts
Any advice before possibly opening a can of worms. I need to drop the lower half of the aluminum sub-frame/crossmember down enough to tighten the bolt that holds the rubber transverse spring clamp. The rear bolt that is accessible broke which I replaced, but the front un-accessible one is loose.
Thanks in advance, Brad |
