960 Speedometer Not Working-Replaced Sensor, Checked the wiring
Hi
I own 1996 960 Petrol Automatic. In the instrument cluster everything works except the speedometer & odometer unit. I checked the sensor wires it was fine and bought a new sensor changed the ABS Speed Sensor. Still facing the same issue. Kindly request to guide what else can be done. Thanks & regards |
Maybe you have a bad cable or an internal problem. You may have to replace the cluster.
