-   Volvo 260, 760 & 960 (https://volvoforums.com/forum/volvo-260-760-960-28/)
-   -   Engine Knocks... What could it be? (https://volvoforums.com/forum/volvo-260-760-960-28/engine-knocks-what-could-44310/)
Big John Aug 8, 2010 02:47 PM
My engine starts fine, but when given gas, the engine starts to knock and the whole car shakes. What could it be? Please help!
96 Volvo 960
213,000 miles
rspi Aug 8, 2010 09:15 PM
Do you have a CEL? If so, have you pulled codes?
kendogg Aug 10, 2010 10:42 AM
What kind of a knock?? Metallic rod knock sound, or sound from the entire engine moving? Check your motor mounts, and check your oil. If you have an oil pressure gauge, check your oil pressure as well.
zmontgomery Aug 15, 2010 03:06 PM
While the car is running unplug your mass air flow sensor. It's on the intake hose right after the air filter box. If the engine smooths out, you've found your problem.
