Knowledgebase for our cars
If you have, and are willing to share, Manuals, Diagrams, and other Volvo documents for our cars you can share them here. I will put my Library up for people to view and download:
Here it is ... https://docs.google.com/folder/d/0B6...xZDRhZTVk/edit
Parts Diagrams can also be seen here -- http://www.volvopartswebstore.com/ This is linked at the "Resources" sticky.
We can use this thread to refer other members to.
We should not use this thread however for advice on how to fix things with our cars; seperate threads should be opened instead.
Last edited by Henry10; Jan 11, 2013 at 09:27 PM. Reason: Added link to Volvo Parts website
Some links to other collections:
Looking to buy -- tell me about the 960 - Turbobricks Forums
Brickboard FAQs: 960 Information
Volvo Maintenance Hints for 7xx/9xx
RSPI's 960: Automotive Tips and Repair Instructions
https://volvoforums.com/forum/volvo-...-1998-a-50553/
Bad Air Pump & SAS Valve - PO410 - Secondary Air - FWD/AWD 1998 and Prior - Volvospeed Forums
Chinese Water Torture (a SeaFoam recipe) - Turbobricks Forums
https://volvoforums.com/forum/volvo-...ulb-out-42248/
BOSCH_M7.4.4_ME7.4.4_EOBD
Volvo 700/900 Heater Core Replacement
'95+ 900 Series Heater Core Replacement. - Turbobricks Forums
Guide to the Volvo PCV system (With video). - Turbobricks Forums
Diy: 98 V70 Brake Hydraulic Overhaul (hoses, Seals, Parking) - FWD/AWD 1998 and Prior - Volvospeed Forums
Volvo tal lights suck. - Turbobricks Forums
960 Intake gasket write-up w/o removing the intake (no-pics)
Swedespeed Forums - Volvo 850 flywheel adaptation for evap system and O2 sensors
Rear Suspension: Calling all '95 965 or '96+ V90 owners... - Turbobricks Forums
steering rack leak...fixable? - Turbobricks Forums
Air Shocks for the 95+ 960 (the anti-nivomat) - Turbobricks Forums
960 Control Arm Bushing install - Turbobricks Forums
Replacing Vacuum Servos in ACC-Equipped 700/900
Differential
Timing Belt Replacement, Video and written instructions:
- https://volvoforums.com/forum/volvo-...97/#post365569
- Turbobricks ForumsSwedespeed Forums - Volvo 850 flywheel adaptation for evap system and O2 sensors
Differential
Hello and forgive me but I am lost a bit on this website, it's me not the site. I saw where it said to use a different thread for fixing our cars but I don't know how to start a thread.
I have a 960 VOLVO and the radiator hose , upper hose will not stay attached to the male lip if you will coming out from the radiator as if it was broken off and there us less than an inch of plastic to affix the hose onto it. looked at the same hose at NAPA and it didn't have the steel center at the end of the hose like mine does. I am confused and not a mechanic. I have no money until I don't know when and I have a family depending on me. I don't know how it happened but its been going through water regularly and now of course water is pouring out. Any insight on this the lip or male end of the radiator that the hose is suppose to fit on ? thank you
[QUOTE=Henry10;339207]If you have, and are willing to share, Manuals, Diagrams, and other Volvo documents for our cars you can share them here. I will put my Library up for people to view and download:
Could you add saldenhundsrfr@gmail.com to the folders. It says I cant view. Thank you!
