Passenger front seat
Old Jun 24, 2010 | 02:14 PM
pturner's Avatar
Default Passenger front seat
hey all,
I bought my 93 960 about three years ago and am slowly working the bugs out. My latest is to tackle the non working passenger side front seat. do any of you have any hints about troubleshooting why it could be locked all the way back with no motion in any direction? I would like to have some steps before I start replacing parts.
thanks.
Old Jun 25, 2010 | 11:26 AM
dan550i's Avatar
Is there any movement? Does the motor make a click?
What usually happens is the motor cable slips out of the gear mechanism on the seat rail for one side, this makes the seat move on one track until it binds up.
There is plenty of info with some searching on that repair. But it is not unheard of to have a bad switch be the problem too.
DanR '94 964 352,000 miles (118,000 on the new engine)
Old Jun 25, 2010 | 11:43 AM
pturner's Avatar
no movement. no sound. I was going to remove the seat and start checking voltages to determine if the controller was gone or if I had any electrical at all. Seems like if it was the switch at least one of the functions would work. I will try the motor cable and electrical connections.
thanks.
Old Jun 25, 2010 | 03:01 PM
dan550i's Avatar
thanks.
I have experienced problems with the switches on my car if they have not been used in a while. They get kind of sticky, thinking that there is internal corrosion of some sort. Toggling the switch many times gets them to work, maybe you are lucky and that is all that it is?
DabR
Old Jun 28, 2010 | 05:56 PM
regrie203's Avatar
I have a passenger seat that moves on one track until it binds up. You mention that there is plenty of info with some searching on that repair.
Where can I find that info?
Thanks,
Regrie
Old Jun 29, 2010 | 11:41 AM
dan550i's Avatar
Thanks,
Regrie
https://volvoforums.com/forum/showth...cable%2C+track
This should help you.
DanR
greenman86
Aug 16, 2013 08:29 AM
jipsy
Jan 22, 2012 06:00 PM
t5killer
Sep 27, 2005 10:01 PM
lenniefoug
Aug 6, 2005 04:33 PM
mphubbar
Apr 13, 2005 02:43 PM
