Question on 960 brake booster
Hi, I have a 1995 960 station wagon and a brake booster that appears to be leaking
on the passenger side of the firewall. As close as I can tell the leak seems to be right where the gaitor (rubber covering a rod) is. Being a cheapskate I am just wondering if anyone has had a similiar leak and if it is worth pulling out and seeing if I can fix the leak before I spend the money to replace it. Also, if anyone out there has an extra brake booster that would fit a 1995 960 I would like to know about it. Thanks very much, Jim Lee 1995 960 Wagon |
Problem is trying to find exactly where the leak is in order to stop it... You can give it a shot, what is the harm? I'd try to get one from a JY, they don't go bad much. They are cheap there...
