Rattle & Clank under car
![Question](https://volvoforums.com/forum/images/icons/icon5.gif)
Scientific progress (imho) should not go boink. Or clank for that matter.
(edit: 1995 960)
While driving (probably due to vibrations from the road, maybe alignment is off a touch, not sure) I get an intermittent (non-rhythmic) clanking sound coming from under the car.
Dealership tells me "front sway bar links excessively loose & nagging"
the only time I have been able to recreate the sound I hear while driving is when the front wheel (I've been doing drivers side) is off and car is on stands, and I use the jack lever to knock on different parts. When I tap on the spring itself (the big big black spring thing [forgive my ignorance?])... maybe it's different hearing from inside vs outside? idk.
Anwyay, how can I test to see if the sway bar links (link ends?) are loose? Pretty sure I've identified the piece, and when I grab it and pull and jerk around with it, it doesn't budge anymore than the frakkin' driveway would.
btw, they want $264 for parts and labor. (I know I could do it myself for 50 - IF it was actually those end links that were the problem! and to think I paid a hundred dollars for diagnostics. Last time I ever go to a dealer when there are other options...)
(edit: 1995 960)
sugardoo
01-30-2015 04:54 PM
