Is there any hope for this AC compressor?
This 960 has an AC that wont come on. The front of the compressor seems loose like the clutch is blown. Is there any hope for it or does it need to be changed?
Your gap is too big. You should be able to re-shim it. You can use's Tech's instructions on 850.
What about the loose part?
Bolts have worked themselves loose. After you re-shim it, apply some blue locktite to the bolts.
