turn off service light??
How do I turn off the service light in my !997 960/ S90??
Is this the service light that comes on every 5k or is this a check engine light? Your car has OBDII so...if it's the check engine light it's pretty much a dealer only fix.
You have a plug in the instrument cluster. Pull the rubber plug out and push something through the hole and it will reset it.
RSPI - you are definitely correct.
:eek:
