Coolant Sensor Light
This doesnt end :)
Here is my story....i had my ABS and check engine lights on and took the car to the dealer for diagnostics ( i have a 2000 V70 Non turbo) and $150 later he tells me i need to replace my ABS module and ECT sensor....His quote to do this close to $2K. In any case with the help from this and other forums i get the ABS module replaced for less than 500 and i am happy as can be...But wait the following day my coolant sensor turns on....i check my Coolant level and it is way down....there seems to be some leakage....take it back to the shop and he tells me my water pump is out.......C'mon now...
So i get the timing belt and water pump replaced for another $600 ( it was due i guess at 110K miles) and then i am happy..
But wait...the coolant light still turns on......Now even though the tank is full the light remains on...even though i did not have that problem before....
Any ideas why this could be happening??? Is it the Coolant Level Sensor? How can i test to make sure that is the problem and not some leakage??I did notice that the coolant level drop some ...
Appreciate your help...cant spend any more money
Timing belt
HI THERE LOOKS LIKE WHEN THEY DONE YOUR WATER PUMP ECT THEY STRETCHED THE WIRE TO THE SENSOR,, WOULD BE THERE FAULT,
I HAVE JUST FITTED TIMING BELT TO MY V70 2001 AND HAD THE SAME PROBLEM STRECHED THE WIRE,, MY MISTAKE,, BUT IN YOUR CASE ITS THEM TO BLAME
HOPE THIS HELPS
COLIN
HOPE THIS HELPS
COLIN
aru5016
06-19-2011 12:26 AM
cisopen
09-20-2010 05:25 PM
