1993 850 cooling fans staying on
Hi
Learned the hard way that age is just as important as mileage when it comes to TB replacement. I have the engine up and running, not to bad on the back, but a little strain on the check book. However, the brain is being taxed beyond what I can find on this site.
The CEL is lite. No codes come up and I can’t clear it.
Rad fan stays running along with the ECU fan until battery is drained.
It is highly possible that something (hose/harness) has not been reconnected properly. Does anyone have any ideas or has anyone experienced this before that can help.
Thanks
78 DL245
81 DL245
84 GT240
98 XC-70
93 DL245
93 850GLT
Thanks
78 DL245
81 DL245
84 GT240
98 XC-70
93 DL245
93 850GLT
It's a thought I'll look into. Read somewhere, can't remember where, what the voltage readings are suppose to be with a good sensor, at the sensor. Do you know where that somewhere would be. Also would about the CEL, about getting the lite to go out. No codes that I can read and I've tried clearing what is not there to get the lite to go out???
