1994 Volvo 850 Turbo SRS Light 232 SRS Module Failure
1994 Volvo 850 Turbo SRS Light 232 SRS module failure
I have not seen SRS issues posted here but I know others have experiences problems with the SRS. I had my car checked out at the Volvo dealership and computer diagnostic said SRS module was bad. I found a used confirmed good SRS Module and installed same. SRS module when out after engine start but came back on after about 3 minutes and remained on. I have reset the 232 code under the hood to 111, disconnected the battery for 15 plus minutes to power off the car's computers, replaced the Driver's side left belt tensioner open circuit 232 cause but the light remains on. I now suspect the wire from the tensioner to the module may be shorted/grounded. I will check the wire when I get more time. Has anyone else experienced SRS problems? In particular 232 code? Dealer is to expensive so either I solve it cheaply or the car goes to the bone yard. SRS is a state inspection failure item so the clock is ticking on my beloved Volvo that still has lots of pep and life. Any constructive suggestions, pointers, or help would be appreciated. |
232 is "Left belt tensioner open circuit", check your connector first.
Checked connection, changed the tensioner, reset the B3 circuit, changed the SRS Module, no luck.
Is there any more information to read about Volvo SRS? |
open circuit could also be a broken wire.
So you will need to ensure that the whole circuit is good, not just one little part of it. |
Going to the junkyard today to pull a SRS module and AC compressor. Wish someone in this forum had some experience with the Volvo SRS system. May have to disconnect the light if this 2nd module fails...... Yeah, Yeah, no airbags but need transportation, just like in 1982..... no airbags then either.
Originally Posted by ShaginWagon
(Post 178057)
1 Attachment(s)
This is the SRS wiring info I found from VADIS, it looks kinda strait.
The SRS system is a pain to fix. I had the same issue you are having on my 940 and I could not for the life of my fix the issue. I ended up just taking the bulb out so that I could pass inspection.
Very helpful, thanks!!!
Originally Posted by confused_al
(Post 178096)
Very helpful, thanks!!! What is VADIS? |
Originally Posted by fcpgroton
(Post 178134)
I may eventually go this route but I am challenged to figure it out. It's only wires and such with a logical reason for the light. SRS troubleshooting information does not exist. |
Are you using junkyard parts or new? It is possible that you got a bad part.
Also, are you performing a capacitor discharge or just disconnecting the battery? This is what I pulled from Alldata for the code 232 (I'm at home so can't check Vida) Conditions For Code Driver/passenger airbag igniters resistance too high (indicating a wiring open circuit). Fault Symptoms None, except for operation of SRS lamp. Fault Source Open circuit in wiring, connectors or airbag module. Action 1. Turn ignition switch to Off position, then disconnect battery ground cable. 2. Disconnect electrical connector of suspect airbag module, then connect special tool 998 8695 to connector. 3. Clear codes, then display codes. 4. If code does not recur within 15 seconds, replace airbag module. If code recurs, proceed as follows: 1. Connect ohmmeter between one of igniter connector pins and corresponding pin in crash sensor connector. Repeat for other pins in two connectors. If resistance is 0 ohm, wiring is intact. If resistance is infinite, module wiring is short circuited. Measurement must not be carried out directly on module, or deployment may result. 2. Check wiring and connectors between crash sensor and module in question. If code 2-1-2 is displayed, also check contact reel for short circuit. Airbag module must be disconnected before carrying out this measurement. 3. Ensure that code does not recur when new module has been installed. |
did you unplug an airbag at some point?
Originally Posted by volvo4mula
(Post 178175)
Also, are you performing a capacitor discharge or just disconnecting the battery? This is what I pulled from Alldata for the code 232 (I'm at home so can't check Vida) Conditions For Code Driver/passenger airbag igniters resistance too high (indicating a wiring open circuit). Fault Symptoms None, except for operation of SRS lamp. Fault Source Open circuit in wiring, connectors or airbag module. Action 1. Turn ignition switch to Off position, then disconnect battery ground cable. 2. Disconnect electrical connector of suspect airbag module, then connect special tool 998 8695 to connector. 3. Clear codes, then display codes. 4. If code does not recur within 15 seconds, replace airbag module. If code recurs, proceed as follows: 1. Connect ohmmeter between one of igniter connector pins and corresponding pin in crash sensor connector. Repeat for other pins in two connectors. If resistance is 0 ohm, wiring is intact. If resistance is infinite, module wiring is short circuited. Measurement must not be carried out directly on module, or deployment may result. 2. Check wiring and connectors between crash sensor and module in question. If code 2-1-2 is displayed, also check contact reel for short circuit. Airbag module must be disconnected before carrying out this measurement. 3. Ensure that code does not recur when new module has been installed. No maintenance action was taken on the SRS system. Light appeared about 10 months ago but not inspection is due so I need some sort of resolution. |
(Post 178176)
No but see my last post for more details. Volvo dealership ran diagnostic on SRS / car and they SRS module was identified as the bad part. Hence the eBay replacement. eBay seller stated that part came from working Volvo with no airbag deployment. I believe the eBay SRS module is OK and my problem is elsewhere within the SRS system. |
Originally Posted by Sparky4688
(Post 178192)
The only way to diag the system right is to have the resistors to plug into the system (airbag simulators). It is highly discouraged that you should try to use any sort of diagnostic equipment on the SRS wires. DMMs use low level dc current to test circuits that could potentially set off an airbag. (FYI a cap discharge is disconnecting the battery cables from the battery and connecting them together to allow the static energy to work itself off. It usually takes about 10 min or so) |
(Post 178310)
No airbag deployment doesn't mean no airbag light.
(Post 178501)
... I will just disconnect the light bulb from the instrument panel...
Regarding to the driver side airbag, the most common problem is the clock spring. It is made by plastic and became brittle over time. I had to replace mine while I was doing my evaporator, because the the plastic base of the clock spring broke into 4 pieces. |
I just found the SRS part in the 95 service menu, but the file size is alot bigger than 19.5kb allowed (19.5k? thats a joke). If your interested give me an email address I'll be glad to send over.
Better yet, I found the link you can down load the zip file yourself. http://www.matthewsvolvosite.com/dow.../Volvo_850.zip |
(Post 178525)
Better yet, I found the link you can down load the zip file yourself. http://www.matthewsvolvosite.com/dow.../Volvo_850.zip A big THANKS to CA!!!!!! Last night when reading the air bag restraint system troubleshooting link there were a few things to try. 1. Disconnect the battery then bridge car's terminals to discharge capacitors, etc. 2. Once step one is complete and after any SRS repairs turn ignition to the on position then reconnect the battery. Note stressed to ensure no one was in the car when the battery is reconnected. This procedure should reset the new SRS module that was installed last week. Wish the "near dead" Volvo luck! |
