1997 850 GLT ABS/Trac Lights On???'s
While driving home from school today both the abs trac lights came on. I also noticed earlier on the info screen in the dash the word "DISC" came up quickly and went away. I talked to my dad who owned the car before me and said it happened before and the Volvo dealership fixed it by replaceing the fron rotors and pads. I did also noticed the rear wheels are squeaking under braking only slightly. Is it a sensor or a bad ABS module??? I go to school at MMI in Orlando FL and can get a free code check at Auto Zone, but running codes will that tell me? To me i think one of the abs sensors is dirty/broken or the rear pads are shot. What do u guru's think? Please e-mail or reply
1997 GLT Wagon[8D]
1997 GLT Wagon[8D]
RE: 1997 850 GLT ABS/Trac Lights On???'s
Not sure if Auto Zone can pull ABS codes. But give it a try.
I would say most likely a bad ABS module.
I would also bet the codes that come up will be for the R/R sensor and Pump Motor.
What Year is the car?
If worse comes to worse let me know and next time you need an Oil change you can bring it into the shop I work at for the oil change and ask for me and I will do the oil change and look it over.I will also try to sneak and pull the codes.
the lights went out again. the word DISC comes up on the info screen then goes away sometimes. I think it has to be a dirty sensor, since a shipped my car over here on an open car carrier and a bently that was on the top rack leaked oil all over my car!
TECH
thank u for the offer, i need an oil change soon and i will talk to u later. If u own a boat i can fix any problem. If u like to snowboard or ski also let me know i own a shop back home and can get u cost on anything including clothing!
ORIGINAL: tech
