1997 850 MCC help!!!
Old Oct 17, 2014 | 08:59 PM
jamesdubbeld's Avatar
Default 1997 850 MCC help!!!
Hey guys,
I have a 1997 volvo 850 GLE. I recently turned the main **** on my MCC (picture below) and it was sticky, but when I turned it something broke and now I can't get the air to blow on anything other then the windshield!
Question- can I use a MCC from another year? They look different then the one I have- will it still work?
Also, anyone have one for sale???
Thank you!
Old Oct 18, 2014 | 04:55 AM
You can likely use a MCC from another year, however, that will probably NOT fix your problem. Also, if they look different, they are probably ECC units.
The MCC system is mechanical so you likely have a broken piece behind the dash which will need to be replaced.
Old Oct 18, 2014 | 04:57 AM
Old Oct 18, 2014 | 04:48 PM
The **** itself broke- you think I've broken something behind the dash as well? How do I figure that out? Will I likely be able to see the broken piece once the unit is removed?
Thanks for the video!
jamesdubbeld
Oct 20, 2014 05:44 PM
DNiefer
Nov 29, 2013 06:38 PM
Rickford
Nov 25, 2012 07:52 PM
Rickford
Jun 27, 2012 07:45 AM
slowrider06
Dec 25, 2008 11:51 AM
