1997 850 suddenly running rough...
I have a '97 850 sedan that's suddenly running rough the past week or two ago. Things I've noticed:
Thanks! |
Is the CEL on?
The CEL is not on.
New development: Now the car sounds like it's groaning every time I turn the wheel. This just happened a few minutes ago. I did some digging around in the forums and it sounds like something needs to be greased, though for the life of me I have no idea where it would be. This may be entirely unrelated, but I honestly don't know at this point. |
I wonder if the power steering pump is low on fluid or getting ready to go out. That would explain why it is groaning when turning and the idle is much worse when turning to the right. If the pump is going out it would create an extra load on the engine, especially at lower speed.
Check the power steering fluid and make sure it is full and the fluid is not burnt. Also check the condition of the serpentine belt. Just a guess at this point but you need to start somewhere. |
| All times are GMT -5. The time now is 10:33 AM. |
