1997 Volvo 850 - Swapping ABS w/o Tracs to ABS w/ Tracs
Hey Folks,
I currently own a 1997 Volvo 850 Turbo Sedan WITHOUT the Tracs option. I have been led to believe that I can simply SWAP my current ABS module Without Tracs for an ABS module With Tracs. (I will swap with a 1997 ABS module With Tracs). I will also obtain the Switch that installs in the Dash. Is the SWAP as simple as this? I have also been led to believe that the ABS sensors (that I currently have at my wheels) will work with the new ABS module With Tracs. That is, that my current sensors enable the Tracs option to work. Please advise, Thank You in Advance, Paul |
RE: 1997 Volvo 850 - Swapping ABS w/o Tracs to ABS w/ Tracs
I'm 95% sure that it's going to be a lot more complicated than that.
| All times are GMT -5. The time now is 11:21 PM. |
