#628 ECU issues?
So as most of you know I sent my spare Turbo ECU to Ipd for re-mapping.
BUT, I was going thru my storage and I found a #628 ECU from a 97 R that I bought like 6 years ago.. I want to throw it in untill my ECU comes home from IPD but I wasnt sure if it would cause any issues... Any Insight:confused: |
Should be able to run it just fine, im running a 97 R ipd stage 1 ecu in my 95
Are you referring to environmental control unit? I had the flashing lights indicating faults in my environmental control unit. Did the check and it called out about 20 codes. Systems acting weird. Is there a source of repair or replacement for 95 850 T5-R?
Originally Posted by danfleming72
(Post 274520)
