850-R & T5-R Factory Production Numbers 850
Fellow 850 Comrades,
I've been busy learning everything I can about the Volvo 850 T5-R and 850-R exported to North America. I found the following on brickboard.com Enjoy! ************************************************** ********** 850-R & T5-R Factory Production Numbers 850 Direct from Volvo: Thank you for contacting Volvo. Information regarding the 850 R series is available online by registering for the "Owner's Circle" section of our website and clicking on "Driving" and then "Older Model Info". Volvo produced approximately 5000 R's between 1995 and 1997. Drive Safely, John Willets Volvo Cars of North America Specs: 95, 96, 97 1995 850 T-5R Sedan See the 1995 850 Maintenance Schedule Volvo's Owners Manual Library -------------------------------------------------------------------------------- FEATURES -------------------------------------------------------------------------------- Safety Driver and front passenger supplemental (air bag and knee bolster) Side Impact Protection System Air Bags Five 3-point, inertia-reel belts. Front seat belts have automatic height adjustment and pretensioners Five padded head restraints (center-rear is adjustable) Anti-lock Brake system (ABS) Side Impact Protection System Daytime Running Lights Remote keyless entry Central power door locking system which can be operated from three positions, includes trunk and fuel filler lid locks Security System Traction control System (TRACS) Interior Dual Zone Electronic Climate Control with separate controls for driver and front passenger AM/FM stereo cassette, Dolby, anti-theft circuitry,4 Channel 160 watt amplifier, CD changer capability, 8 speakers 8-way power adjustable driver's and passengers seat with 3-position memory and adjustable lumbar support Graphite leather seating surfaces with distinct inserts Tilt/telescopic Leather steering wheel Black Burled Walnut trimmed instrument panel and floor console Power glass sunroof with slide and tilt positions and sliding sun shade Cruise control Front and rear floor mats Front door-panel storage pockets. Front seat back storage pockets Long-load pass through to trunk Tool kit Interior cabin light delay Two entry lights (in front door foot wells) Four, front and rear reading lamps Illuminated, lockable glove box Illuminated vanity mirrors in driver's and front passenger's sun visors Luggage compartment light Split 60/40 folding rear seat; front passenger seat backrest folds forward Integrated child booster cushion in rear center armrest *For children age 3 and over, weighing between 50-80 lbs (23-36kg) and between 46 and 54 in. (117 and 137 cm.) in height. Four cargo tie-down rings Power windows with auto down for driver's window Trip computer Heated front seats Outside ambient temperature gauge with freezing warning Exterior Dual power mirrors with heating elements Tinted windows Two-speed windshield wipers with intermittent cycle Rear-window defroster with automatic timer Open door traffic warning lights on doors Special Lower front Bumper and spoiler with integrated fog lights Rear fog light 7" x 17" 5-Spoke Titanium Grey Alloy Wheels. 205/45/17 ZR Rated Pirelli P-Zero Tires; 6.5" x 16" 5-Spoke Metallic Grey Alloy. 205/50/16 ZR Rated Tires. No Charge (OPTION); Rear-spoiler stainless steel door sill plates Wiper washer system for headlights Engine Transversely mounted, 2.3 liter, 5-cylinder double overhead cam, 4 valves per cylinder, aluminum engine block, forged vanadium steel crankshaft and connecting rods, cast-in iron cylinder liners, interior piston cooling nozzles, sodium filled exhaust valves, water cooled turbo housing, microprocessor-controlled multi-point, direct port fuel injection system with Lambda Sond. Electronic ignition system with knock sensor. Exhaust driven turbocharger with intercooler Horsepower (SAE net): 240 @ 5200 rpm Torque (ft/lbs., SAE net): 221 @ 2100 rpm Compression Ratio: 8.5:1 Transmission 4-speed microprocessor-controlled automatic with lock-up torque converter and selectable shift modes (Economy/Sport/Winter) Final drive ratio: 2.54 Suspension MacPherson strut with asymmetrically mounted coil springs, hydraulic shock absorbers, 21 mm stabilizer bar. Delta-Link semi-independent rear suspension with coil springs, extra firm gas-filled shock absorbers, 20 mm stabilizer bar. Tires 7" x 17" Titanium Grey 5-Spoke Alloy Wheels. 205/45/17 ZR Rated Pirelli P-Zero Tires; 6.5" x 16" 5-Spoke Metallic Grey Alloy. 205/50/16 ZR Rated Tires. No Charge (OPTION); Steering Power-assisted rack and pinion, 34.5 ft. turning circle, 3.2 turns, lock to lock Brakes Four-wheel, power-assisted disc brakes. Front: 11-inch diameter, ventilated discs with sliding calipers. Rear: 11.5-inch diameter solid discs; Proportioning valve on rear brakes. Three-channel anti-lock braking system (ABS); Separate self-adjusting mechanical drum parking brakes Dimensions and Weights Wheelbase 104.9 in. 266.5 cm. Overall Length 183.5 in. 466.0 cm. Overall Width 69.3 in. 176.0 cm. Overall Height 55.7 in. 141.5 cm. Front Track 59.8 in. 152.0 cm. Rear Track 57.9 in. 147.0 cm. Trunk Capacity 14.7 cu ft. .42 m3 Curb Weight 3148-3208 lbs. 1431-1458 kg. Interior Total Volume 111.5 cu ft. 3.16 m3 Color & Upholstery Colors Black, Yellow Upholstery Black Options Sport Suspension Package 21 mm front stabilizer bar, 20 mm rear stabilizer bars, extra firm shock absorbers (OPTION) 1996 850 R Sedan See the 1996 850 Maintenance Schedule Volvo's Owners Manual Library -------------------------------------------------------------------------------- FEATURES -------------------------------------------------------------------------------- Safety Driver and front passenger supplemental (air bag and knee bolster) Side Impact Air Bags Five 3-point, inertia-reel belts. Front seat belts have automatic height adjustment and pretensioners Five padded head restraints (center-rear is adjustable) Anti-lock Brake system (ABS) Side Impact Protection System Daytime Running Lights Remote keyless entry with alarm Central power door locking system includes trunk and fuel filler lid locks Traction control System (TRACS) Interior Dual Zone Electronic Climate Control SC-815 Premium Sound System with in dash CD, cassette, eight speakers, 200 watts amplifier, anti-theft coding, pre-wired for Volvo Compact Disc Changer 8-way power adjustable driver's seat with 3-position memory; 8-way power adjustable passenger seat with 3-position memory. Split leather and Alcantara suede upholstery Tilt/telescoping Leather steering wheel with color accents Scandinavian Light Birch or Black Burled Walnut wood trim on instrument panel and floor console Power glass sunroof with slide and tilt positions and sliding sun shade Cruise control Front and rear floor mats Front door-panel storage pockets. Front seat back storage pockets Long-load pass through to trunk Tool kit Interior cabin light delay Two entry lights (in front door foot wells) Four, front and rear reading lamps Illuminated, lockable glove box Illuminated vanity mirrors in driver's and front passenger's sun visors Luggage compartment light Split 60/40 folding rear seat; front passenger seat backrest folds forward Four cargo tie-down rings Power windows with auto down for driver's window Trip computer Heated front seats Outside temperature gauge Exterior Dual power mirrors Tinted windows Two-speed windshield wipers with intermittent cycle Rear-window defroster with automatic timer Open door traffic warning lights on doors Special Lower front Bumper and spoiler with integrated foglights Rear fog light 7" x 17" Titanium Grey Seven-Spoke Alloy. 205/45/17 ZR Rated Pirelli P-Zero Tires; 6.5" x 16" Five-Spoke Alloy. 205/50/16 ZR Michelin MXM. No Charge (OPTION); Rear-spoiler Stainless steel door sill plates Headlamp washer/wiper Engine Transversely mounted, 2.3 liter, 5-cylinder double overhead cam, 4 valves per cylinder, aluminum engine block, forged vanadium steel crankshaft and connecting rods, cast-in iron cylinder liners,microprocessor-controlled multi-point, direct port fuel injection system with Lambda Sond. Electronic ignition system with knock sensor. Horsepower (SAE net): 240 @ 5200 rpm Torque (ft/lbs., SAE net): 221 @ 2100 rpm Compression Ratio: 8.5:1 Transmission 4-speed microprocessor-controlled automatic with lock-up torque converter and selectable shift modes (Economy/Sport/Winter) Final drive ratio: 2.54 Suspension MacPherson strut with asymmetrically mounted coil springs, forged aluminum lower link arms, hydraulic shock absorbers, 21 mm stabilizer bar. Delta-Link semi-independent rear suspension with coil springs, gas-filled shock absorbers, 20 mm stabilizer bar Tires 7" x 17" Titanium Grey Seven-Spoke Alloy. 205/45/17 ZR Rated Pirelli P-Zero Tires; 6.5" x 16" Five-Spoke Alloy. 205/50/16 ZR Michelin MXM. No Charge (OPTION); Steering Power-assisted rack and pinion, 34.5 ft. turning circle, 3.2 turns, lock to lock Brakes Four-wheel, power-assisted disc brakes. Front: 11-inch diameter, ventilated discs with sliding calipers. Rear: 11.5-inch diameter solid discs; Proportioning valve on rear brakes. Three-channel anti-lock braking system (ABS); Separate self-adjusting mechanical rear-wheel drum parking brakes Dimensions and Weights Wheelbase 104.9 in. 266.5 cm. Overall Length 183.5 in. 466.0 cm. Overall Width 69.3 in. 176.0 cm. Overall Height 55.7 in. 141.5 cm. Front Track 59.8 in. 152.0 cm. Rear Track 57.9 in. 147.0 cm. Trunk Capacity 14.7 cu ft. 1.6 m3 Curb Weight 3148-3208 lbs. 1431-1458 kg. Interior Total Volume 111.5 cu ft. 12.4 m3 Color & Upholstery Colors Black, Red, White Upholstery Alcantara Beige or Grey 1997 850 R See the 1997 850 Maintenance Schedule Volvo's Owners Manual Library -------------------------------------------------------------------------------- FEATURES -------------------------------------------------------------------------------- Safety Driver and front passenger supplemental restraint system (air bag and knee bolster) Side Impact Protection System Air Bags Five 3-point, inertia-reel belts. Front seat belts have automatic height adjustment and pretensioners Five padded head restraints (center-rear is adjustable) Anti-lock Brake system (ABS) Side Impact Protection System Daytime Running Lights Remote keyless entry with alarm Central power door locking system which can be operated from three positions, includes trunk and fuel filler lid locks Prewiring for security system & front fog lights Traction Control (TRACS) Interior Dual Zone Electronic Climate Control SC-815 Stereo cassette with in-dash CD, eight speakers, 200 watts 8-way power adjustable driver's seat with 3-position memory; 8-way power adjustable passenger seat with 3-position memory; Adjustable driver's seat with lumbar support Split leather and Alcantara (Suede upholstery); Leather-faced upholstery (OPTION) Leather-wrapped steering wheel with color accents Scandinavian light birch or burled black walnut wood trim on instrument panel and floor console Power glass sunroof with slide and tilt positions and sliding sun shade Cruise control Front and rear floor mats Front door-panel storage pockets. Front seat back storage pockets. Long-load pass through to trunk Tool kit Interior cabin light delay Two entry lights (in front door foot wells) Four front and rear reading lamps Illuminated, lockable glove box Illuminated vanity mirrors in driver's and front passenger's sun visors Luggage compartment light Split 60/40 folding rear seat; front passenger seat backrest folds forward Four cargo tie-down rings Power windows with auto down for driver's window Center console with cupholders. Trip Computer Exterior Dual power mirrors Tinted windows Two-speed windshield wipers with intermittent cycle Rear-window defroster with automatic timer Open door traffic warning lights on doors Prewiring for security system & front fogs Rear fog light 17" seven spoke Alloy Wheels with high performance tires Special lower front bumper and spoiler with integrated fog lights Engine Transversely mounted, 2.3 liter, 5-cylinder , exhaust driven turbocharger with intercooler, 4 valves per cylinder, aluminum engine block, forged vanadium steel crankshaft and connecting rods, cast-in iron cylinder liners, microprocessor-controlled multi-point, direct port fuel injection system with Lambda Sond. Electronic ignition system with knock sensor. Horsepower (SAE net): 240 @ 5600 rpm Torque (ft./lbs., SAE net): 221 @ 2100 rpm Compression Ratio: 8.5:1 Transmission 4-speed microprocessor-controlled automatic with lock-up torque converter and selectable shift modes (Economy/Sport/Winter) Final drive ratio: 2.54 Suspension MacPherson strut with asymmetrically mounted coil springs, hydraulic shock absorbers, 20 mm stabilizer bar. Delta-Link semi-independent rear suspension with coil springs, gas-filled shock absorbers,19.5 mm stabilizer bar Tires 7x17 Seven-spoke Alloy; 205/50/16 ZR Rated tires Steering Power-assisted rack and pinion, 34.5 ft. turning circle, 3.2 turns, lock to lock Brakes Four-wheel, power-assisted disc brakes. Front: 11-inch diameter, ventilated discs with sliding calipers. Rear: 11 1/2-inch diameter solid discs; Three-channel anti-lock braking system (ABS); Separate self-adjusting mechanical rear-wheel drum parking brakes Dimensions and Weights Wheelbase 104.9 in. 266.5 cm. Overall Length 183.5 in. 466.0 cm. Overall Width 69.3 in. 176.0 cm. Overall Height 55.7 in. 141.5 cm. Front Track 59.8 in. 152.0 cm. Rear Track 57.9 in. 147.0 cm. Trunk Capacity 14.7 cu ft. .41 m3 Curb Weight 3148-3208 lbs. 1431-1458 kg. Interior Total Volume 111.5 cu ft. 3.1 m3 Color & Upholstery Colors Black, White, Bright Red Upholstery Leather: Ivory, Graphite, Light Grey Split Leather and Alcantara Suede: Beige, Grey Plush: Beige, Grey, Graphite Velour: Beige, Graphite, Light Grey Options Cold Weather Package Heated front seats, Wiper washer system for headlights, Outside ambient temperature gauge with freeze warning |
The link to the information would have been enough. ;)
Thank You for the Spam...:rolleyes:
I didn't see any production numbers. Useless info.
Tough crowd :rolleyes:
As per posted comments:
I'm looking forward to read constructive replies ;) |
Tinted windows? Neither of my cars have tinted windows.
Originally Posted by T5-Rennen
(Post 340909)
[*]Show me on this forum where the data was duplicated (spammed)
Good info though Sorry for mistaking you for spam..:p |
(Post 340909)
As for production numbers, yes sites come and go, which could include this one. :eek: If you or anyone else googles "Volvo t5r", they will likely find that posted info all day long. The best source for that info is the actual Volvo site. It has good info about "Thor". The Wiki page is actually more informational than the info above when it comes to production numbers. I guess I just don't like the title because good info to me would be like this: The USA received 914 of the 2,000 T-5R's that were sold in 1995. Of the 914 cars, 185 of them were yellow. Of the 185 yellow's, 35 were wagons and 150 were sedans. Of the balance, there were 5 to 10 special order GREEN wagons shipped to the US. The rest of the 914 (729), they were black. 504 Sedans and 250 wagons. Now for the fun part. There are likely approximately 33 yellow wagons still in the US. There are approximately 97 yellow sedans. There are approximately 47 black wagons. No idea of the number of black sedans, likely around 230. As for the features and equipment the cars had when produced, has nothing to do with production numbers and that is 98% of the information posted in the thread. :confused: |
(Post 340909)
| All times are GMT -5. The time now is 01:58 AM. |
