850 Spark Plugs
What kind of spark plugs should i use in my 850. What do you guys use?
Oem is best...I've tried other plugs and they just aren't as good.
turbo or non- turbo?
OEM all the way. No fancy plugs.
Genuine Volvo plugs are probably the best. I used to use Bosch Platinum 4-ground electrodes and never had a trouble.
Platinum/Iridium tipped plugs are generally factory-set for the gap and re-gaping is usually not recommended due to a possible damage to the electrode(s). JPN |
1 Attachment(s)
You can't get the OEM plug for it. That was a Champion plug that's been discontinued.
I'm running AC Delco platinum PN 41-800 without any problems on a 95 2.3L turbo |
(Post 338780)
1993-1997 Volvo 850 Genuine Volvo Spark Plug Set Am sure other plugs will work but folks tend to get religious about these things; main thing is gap should be .028". |
| All times are GMT -5. The time now is 07:54 AM. |
