850 turbo. abs, srs,traction control lights on after rebuild
i rebuilt the engine, replaced the transmission and changed the gear in the gauge cluster to read mileage on the OD again. im not sure why my abs, srs and traction control lights are on, otherwise the car runs great. This car is an automatic if that helps
What year is it? If it is a 94 - 95, you can check to see what codes are in the computer. If not then you would need to get a scanner to check for codes.
In the mean time, I would disconnect the battery to see if it resets the ABS computer. More then likely the ABS controller is fault and needs a rebuild. |
