97 Volvo 850 GLT, A/C good, but noisy
Whenever A/C is on, there are noises around compressor. No noise at all when A/C is off.
A/C is cold and never stops.
A serpentine belt or idler pulley problem? The timing belt was changed this Feb.
After search on this forum, I think I already get the answer, right?
http://www.youtube.com/watch?v=eee3-7EhcXA
Here are what I have done: start engine, turn on A/C at 00:00:34, turn off it at 00:00:46, turn it on again at 00:00:50, turn it off at 00:01:04, race the engine at 01:00:07. You can hear the noise caused by turning on A/C.
Any easy way to add it?
I found it not easy as i thought.
http://www.ehow.com/how_4762765_add-oil-ac-compressor.html
Thats a much longer route. What I do is get a can of 'Redtek' oilcharge from partsource and connect it to the adapter kit and connect the kit to lowpressure side port. Start the car with airconditioning on and just empty the can into the system following simple instructions.
Cost= Less then $15 and total time is less then 10 minutes.
Following links might give you some information and wath the video in first link:
http://www.redtek.com/products_refr.html#
http://www.redtek.com/win_oilcharge_prod.html
#18
I have been to Autozone this morning, and they have PAG recharge kit.
For Volvo 850, which viscosity is best? I think 100 is OK.
#19
#20
