ABS light on: 850 advice
Hello: I have an 850 and recently had a blow out on the freeway. I was able to brake safety and get off the freeway. However, now my ABS light is on all the time. The brakes work fine and I plugged in an OBDII to see fault codes and found nothing.
Any advice would sincerely be appreciated.
Cheers
Cheers
You most likely damaged the ABS wheel sensor or the wiring to it on the wheel you had the blow out on.
You should be able to access the codes from your under hood self diagnostic panel (OBD1) on the passenger side by the washer fluid fill neck.
Instructions from Volvo Speed:
Volvo Performance Repairs And Modifications
I have a '97 850. My ABS light used to come occasionally but would go away by itself while driving or when I shut the car off and then it wouldn't come back on after restart. Recently is has been coming on and staying on pretty much all of the time. It is now only occasionally off. Tried checking codes, but I think ABS codes are not read the same way as other codes. Any tips on where to start looking or how to start looking?
I just thought of something else that may be related. The center brake light is also occasionally cutting out. I had problems in the past with this and changed the bulb and the sensor on brake pedal and it has not been doing it anymore since then. I can't recall if the light cutting out and the ABS light coming on started at the same time.
Last edited by jrmcgove; Sep 17, 2012 at 04:27 PM. Reason: Thought of something else that may be important
