ABS Light just started coming on every now and then.
about 2000 miles ago my abs light came on once, I drove it 1500 miles and didnt have it come on at all. Now in the last 300 miles it has come on 3 times. Any ideas where to start?
RE: ABS Light just started coming on every now and then.
The ABS module is most likely bad.
But you should have the codes pulled to see. |
check your individual wire connections to the abs modules on each wheel. Mine had been severed and I just had to reconnect w. new module. Never hurts to look. A lot cheaper than rebuild on ABS module. Most likely the module is bad. Common problem on these cars.
ABS controller has some loosed connection on the circuit board. I do not know how to open the module. I can be repaired at about $75. I paid $150 to get mine fix by Mr. Rocha in Southhern CA. I saw another ad last time for $75 I just can't remember where. Try searching. Good Luck!
