-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   ABS pump with TRACS leaking fluid (https://volvoforums.com/forum/volvo-850-16/abs-pump-tracs-leaking-fluid-62689/)
jackson2600 May 8, 2012 06:56 AM
Howdy,
1995 850 ABS pump is leaking brake fluid between the metal block with the 4 brake line ports and the plastic cover....Has anyone been able to solve this problem?
Thanks,
Steve
PlatyPius May 25, 2017 01:02 PM
I'm guessing that's a No, since no one has replied in 5 years. I'm having the same problem. Replaced it with a used one. Same thing.
mt6127 May 29, 2017 11:20 AM
what did you replace? When I had issues on my S40, I had to replace the valve body (where the lines bolt in) so I just got a complete unit at a yard - pump, valves, controller.
PlatyPius May 29, 2017 11:24 AM
I replaced the whole unit. It lasted for 2 days before it started leaking, too. They're going to send me another one. If that doesn't fix it, I'm going to burn the damn car to the ground.
hungryman54 Nov 15, 2023 02:04 AM
Great sadness
My 95 850 is doing the same thing. Accessibility is not reasonable. Hopefully, I can repair. Appears to be leaking around the edges of the pump. Gasket?
