ABS/Trac..Lights on
Old Apr 20, 2011 | 07:32 AM
vol's Avatar
vol
Question ABS/Trac..Lights on
Hi all my name is Vol & I have a 854-R 1996, I have a a fault coming up on the dash board the Abs/trac light comes on now & again.. I does this three times a week or so.. could anyone Know how to deal with this problem..?
Old Apr 20, 2011 | 07:42 AM
gilber33's Avatar
Go to the dealership and get the codes pulled since a normal scan tool can't read ABS codes. Once you have the codes, come back and update us, unless we know what the codes are, there are countless things it could be and it wouldn't make any sense at all to just dive in without knowing what exactly is wrong.
Get codes pulled, let us know what the codes are, then go from there.
Old Apr 20, 2011 | 07:55 AM
vol's Avatar
vol
Hi Gilber33 thanks for the information on the Garage, do you think that it would be expensive to have the codes pulled from a Volvo dealer..?
Old Apr 20, 2011 | 08:48 AM
gilber33's Avatar
shouldn't be. only takes a few seconds.
Old Apr 20, 2011 | 09:26 AM
brianb's Avatar
Mine would come on at times and the ABS and traction control would kick on for no reason. It turned out the ABS sensors on the front wheels were filthy and there was some gunk on the ABS ring. After cleaning that, the light has not come on and the ABS/traction control has been fine.
Old Apr 21, 2011 | 04:58 AM
vol's Avatar
vol
Thanks for the info about the wheel sensors, will check it out @ the wk-end will let you Know how I get on brianb =))
Old Apr 21, 2011 | 07:25 PM
MattyXXL's Avatar
Do you have any speedo issues?
Old Apr 24, 2011 | 09:41 AM
vol's Avatar
vol
Hi brianb, vol here I did the ABS sensors, over the wk-end & the light on the dash went out but here today it came back on a couple of times ..? I did the back ones today..& they were really bad with build up off gunk & metal shavings, dont think that I have solved the problem..?
Old Apr 24, 2011 | 09:44 AM
vol's Avatar
vol
No issues with speedo.! Vol
Old Apr 24, 2011 | 10:14 AM
vjaneczko's Avatar
Sounds like the ABS module is starting to die - they all do from the 850's. Here's a post on how to fix it yourself, if you choose.
http://www.matthewsvolvosite.com/for...?p=46827#46827
If not, there's a few people that'll fix them for you much cheaper then a stealership - Matty Moo, for example: http://www.matthewsvolvosite.com/for...131380#p131380
Old Apr 26, 2011 | 01:28 PM
Henry10's Avatar
Yes, there is high probability that the module is bad, but speedo might also mis-behave, which MattyXXL was alluding to... Get the codes pulled first. Have you cleaned the wheel sensors and their toothed rotors? Any cuts or overextended wires at the front wheel-wells?
Old Apr 27, 2011 | 05:43 AM
vol's Avatar
vol
Thanks for the info on the ABS module, also thanks for the links
will let you know how I get on..Vol
Old Apr 27, 2011 | 05:56 AM
vol's Avatar
vol
Hi Henry10..last week I cleaned the wheel sensors, they were in a bad way with road gunk, & greasy resadue, now I see that you asked me did I clean there toothed rooters..? Is that were they slot back in to..? Last Saturday I took off the back wheel sensors & gave them a clean also, all lights stayed off since then , but last night I blew the horn on the car & the ABS/Trac light came straight back on..? As I says to, MattyXXL, I dont have any issues with the speedo+ all the wiring to the sensors has been cleaned & also checked for cuts, no problems with the wiring that is visable..?
Old Apr 27, 2011 | 06:29 AM
Henry10's Avatar
Toothed rotors -- Volvo calls them "Sensor wheels". This is what the speed sensor reads off of. See # 22 on this diagram Drive shaft 5CYL 2WD. Fits: 850 | VolvoPartsWebstore.com
Having codes pulled does help, but if you don't have a cheap way to do this, you might want to go ahead and pull the module and check/repair that (if you DIY). '96-'97 modules consistently fail at their solder joints -- this was under-engineered and has been proven so.
Old May 2, 2011 | 08:53 AM
vol's Avatar
vol
Hi Henry10.. I was all over the car @ the wk-nd & I noticed that the back brake Pads
were nearly down to the metal..so I went to my Local Volvo dealer this morning got some New brake Pads & low & behold the ABS/Trac lights have gone out since fitting the New Pads.! Do you think that the wheel sensors were picking up the information..that the old Pads, were worn out.?
Old May 2, 2011 | 01:33 PM
Henry10's Avatar
ABS sensors do not read wear on the pads. Chances are -- technician blasted some Brake Clean spray at the toothed wheel and sensor and cleaned the gunk/rust. Ask the dealer...
Old May 2, 2011 | 02:25 PM
  #17
vjaneczko's Avatar
Probably a good idea to pull all the wheels and get at the 'ABS teeth' with a tooth brush to scrub 'em good.
Old May 3, 2011 | 06:40 PM
  #18
the detail man's Avatar
The same thing happen to me with the dash lights coming on and it was the ignition.
Michael B Hasson
850 t5R
Old Aug 11, 2016 | 06:05 PM
  #19
peterx2's Avatar
Default ABS/TRACS light
This happened to me on my 1994 850. I ususally unplug electricaal connectors and spray them lightly with wd-40 to clean up the contacts. this works most of the time and did with this problem. also should do the same with plugs leading to low current sensors.
Old Aug 29, 2017 | 10:31 PM
  #20
dannyyfrsh's Avatar
Hey there, this light situation just came on in my 94 850 as well... which electrical connectors are you talking about and how do I access them? Thanks
