ABS/Trac..Lights on
Hi all my name is Vol & I have a 854-R 1996, I have a a fault coming up on the dash board the Abs/trac light comes on now & again.. I does this three times a week or so.. could anyone Know how to deal with this problem..?:confused:
Originally Posted by vol
(Post 267418)
Get codes pulled, let us know what the codes are, then go from there. |
Hi Gilber33 thanks for the information on the Garage, do you think that it would be expensive to have the codes pulled from a Volvo dealer..?
(Post 267425)
Mine would come on at times and the ABS and traction control would kick on for no reason. It turned out the ABS sensors on the front wheels were filthy and there was some gunk on the ABS ring. After cleaning that, the light has not come on and the ABS/traction control has been fine.
Thanks for the info about the wheel sensors, will check it out @ the wk-end will let you Know how I get on brianb =));)
Do you have any speedo issues?
Originally Posted by brianb
(Post 267443)
Originally Posted by MattyXXL
(Post 267691)
Sounds like the ABS module is starting to die - they all do from the 850's. Here's a post on how to fix it yourself, if you choose.
http://www.matthewsvolvosite.com/for...?p=46827#46827 If not, there's a few people that'll fix them for you much cheaper then a stealership - Matty Moo, for example: http://www.matthewsvolvosite.com/for...131380#p131380 |
Yes, there is high probability that the module is bad, but speedo might also mis-behave, which MattyXXL was alluding to... Get the codes pulled first. Have you cleaned the wheel sensors and their toothed rotors? Any cuts or overextended wires at the front wheel-wells?
Originally Posted by vjaneczko
(Post 268016)
http://www.matthewsvolvosite.com/for...?p=46827#46827 If not, there's a few people that'll fix them for you much cheaper then a stealership - Matty Moo, for example: http://www.matthewsvolvosite.com/for...131380#p131380 will let you know how I get on..Vol |
Originally Posted by Henry10
(Post 268396)
(Post 268505)
Hi Henry10..last week I cleaned the wheel sensors, they were in a bad way with road gunk, & greasy resadue, now I see that you asked me did I clean there toothed rooters..? Is that were they slot back in to..? Last Saturday I took off the back wheel sensors & gave them a clean also, all lights stayed off since then , but last night I blew the horn on the car & the ABS/Trac light came straight back on..? As I says to, MattyXXL, I dont have any issues with the speedo+ all the wiring to the sensors has been cleaned & also checked for cuts, no problems with the wiring that is visable..?
Having codes pulled does help, but if you don't have a cheap way to do this, you might want to go ahead and pull the module and check/repair that (if you DIY). '96-'97 modules consistently fail at their solder joints -- this was under-engineered and has been proven so. |
Hi Henry10.. I was all over the car @ the wk-nd & I noticed that the back brake Pads
were nearly down to the metal..so I went to my Local Volvo dealer this morning got some New brake Pads & low & behold the ABS/Trac lights have gone out since fitting the New Pads.! Do you think that the wheel sensors were picking up the information..that the old Pads, were worn out.? |
(Post 269205)
+1
Probably a good idea to pull all the wheels and get at the 'ABS teeth' with a tooth brush to scrub 'em good. |
The same thing happen to me with the dash lights coming on and it was the ignition.
Michael B Hasson 850 t5R |
ABS/TRACS light
(Post 267418)
Originally Posted by peterx2
(Post 436049)
This happened to me on my 1994 850. I ususally unplug electricaal connectors and spray them lightly with wd-40 to clean up the contacts. this works most of the time and did with this problem. also should do the same with plugs leading to low current sensors.
| All times are GMT -5. The time now is 01:17 AM. |
