Air Conditioning disconnect
Is there a way to stop the compressor from kicking in when I turn on the defroster? My AC isn't working correctly (leaking somewhere) and I would like to use the defroster when the call arises without the compressor cycling all the time. I know I should just fix it, but I need to put money into other things for the next 6 or 7 months.
RE: Air Conditioning disconnect
Are you still using the A/C?
If not just unplug the A/C compressor and leave it unplugged. |
ORIGINAL: tech Are you still using the A/C? If not just unplug the A/C compressor and leave it unplugged. |
Yes, there is a harness on the sensor. If it is unplugged, the compressor shouldn't come on. It is on the hard line near the firewall on the passenger side (US).
Agreed that would be the Low pressure switch. But it might make the lights on the dash flash all the time.
The Compressor has a single wire that mounts on the side of the compressor in a white plug. Looking at it it faces the Radiator. |
