battery
Old Feb 24, 2005 | 11:34 PM
ahn2u's Avatar
Default battery
I have just recently replaced the battery twice in 2 months. How can I tell if there is an open circuit draining the battery or if the battery was just bad to begin with or because I didn't drive the car for several weeks?. The battery was completely dead.
Old Feb 24, 2005 | 11:55 PM
Default RE: battery
Do you have a voltmeter that measures amps?If you do then you can see how much of a draw there is.
Old Feb 25, 2005 | 01:02 AM
ahn2u's Avatar
Default RE: battery
my voltmeter measures from 2 mAmps to 200 mAmps, will that work? What kind of draw am I looking for? With the cables disconnected it looks like there maybe a little resistance from the positive terminal, probably due to some corosion.
Old Feb 25, 2005 | 11:20 AM
Default RE: battery
Does it read milla amps only?You should have a reading of about .50.You disconnect the positive cable and put on lead on the battery and the other lead on the cable.To avoid a big spike of amps and blowing the fuse in the meter.Put the leads on both the battery and the cable then slide it off the battery.You should have I think like .50.If you have more start pulling fuses one at a time and watch for the amps to drop.When they do that is the curcuit that the fault is in.
Jeffers
Nov 21, 2012 06:50 PM
mrcanon918
Sep 24, 2009 12:35 PM
cmercon
Feb 2, 2009 02:15 AM
Chris Campbell
Apr 2, 2005 11:18 PM
dkhorne
Feb 11, 2005 10:02 AM
