Brake Lights
Our 1996 850 has no brake lights. I looked for the switch under the brkae pedal but couldn't find it. Can someonr tell me where it is?</P> |
Brake Lights
heres the instructions from the haynes for removal:</P> 1.)Detatch the cable from the negative terminal of the battery.</P> 2.)Remove the trim panel under the instument panel on the driver's side. On cars equipped with an airbag, remove the kneeguard beneath the steering column.</P> 3.)Depress the brake pedal slightly then push the stop light switch towards the pedal to release the locking sleeve</P> 4.)Pull the locking sleeve towards the switch plunger as far as it will go</P> 5.) Compress the switch side retaining catches and withdraw the switch from the pedal bracket. Disconnect the wiring connector and remove the switch.</P> </P> Hope that helps</P> |
