-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   Brake pedal position sensor? (https://volvoforums.com/forum/volvo-850-16/brake-pedal-position-sensor-43498/)
mojorysn Jul 16, 2010 12:34 AM
1995 850 turbo sedan
The car has been acting funny lately so I put it on a diagnostic and it said there was a fault with the brake pedal position sensor and a O2 sensor. When driving, every few minutes it feels like the cruise control is engaging for a split second and the car pulls and kind of thuds. I'm a total novice, and I looked up the sensor and a new one is like $500. I've had Volvos long enough to know that I can probably find one used, and I also read that you can get them re-sautered to work? Does this sound like a brake pedal position sensor to you? Any information or advice you have is much appreciated. Oh, and is it dangerous to drive the car right now?
fcpgroton Jul 16, 2010 07:55 AM
Are you tracs and ABS lights on? If so, then it is more then likely the pedal sensor.
As for the O2 sensor, I would check for vacuum leaks first before replacing them.
1996850turbo Jul 16, 2010 08:48 AM
There is a thread somewhere on fixing the brake pedal sensor. I have done it and it worked. You need to be REALLY CAREFUL with the plastic housing but the repair itself is easy.
fcpgroton Jul 16, 2010 03:16 PM
I just brought a used one for 50 bucks because I did not trust myself with the plastic housing.
vpatrol Jul 16, 2010 07:45 PM
I repaired mine about 8 months ago. There was a good thread showing you how to do it. Often the culprit is poor solder. The plastic casing provided the most difficulty. Some have had success opening it up without damage, I wasn't one of them. I cut it open and just used a plastic weld attachement for the soldering iron to seal it up again. Don't forget to silicone the top up to seal it. Took me about 15 mins to open it up and maybe 10 mins to repair and re-seal it. Still works great. Without it working properly, I think it just disables the ABS.
mojorysn Jul 17, 2010 08:36 AM
Re: Brake Pedal Position Sensor
Thank's guy's... I found a used one I hope. Do any of you have any advice on how to remove this circlip on the sensor I don't have good tools just basics.
ElloElloEllo Feb 2, 2011 03:01 PM
My own updated and ENGLISH 'how to':
http://www.volvoforums.org.uk/showth...t=97192&page=5
Thanks.
KC1 Feb 12, 2014 11:02 PM
Sensor O-ring Placement
Does anyone know where the O-ring goes exactly
Originally Posted by ElloElloEllo (Post 254909)
