A/C Compressor Clutch Reshimming
Once compressor is off set it like the following pic and remove the 10mm screw in the middle of the pulley.
Then carefully remove the outer part of the Clutch.(There is a special tool which I didn't have I used to screw drivers but be careful)
Then either the shims will come out with the outer peice like mine did or they will be sitting on the shaft once the outer part is removed.
If you look closely the washers/shims are different thicknesses. You will need to Measure the thickness and then find one a little thinner and reinstall and check the Gap between the outer and inner part of the clutch.
I will have to find out the exact specs but I believe it needs to be .016 Cannot be more than .020.
Use a fueller gauge to measure the gap.
Hopefully this helps.
If you have any questions feel free to ask.
Compressor Specs: Gap should be between .3MM(.012Inches) and .5MM(.020Inches)
.6mm(.024) should not fit in at all
Tech... excellent post. Just to clarify, I should be measuring between the clutch surfaces, and I'm guessing the gap will be bigger than the spec (due to clutch wear) thus, going with a thinner shim will bring it back into spec?
Wear would I get the correct shims? Thanks - AB
Yes you are correct.
I used small washers that were close to the size of the shims.
Volvo only sells 4 shims for it.
If I needed to go thinner on the washer I rubbed it on a file to thin it out.
A 30 minute job put my 96 850 AC clutch back in order. I had heard that if AC is on, compressor wheel is turning but will not engage, I could take a broom stick and lightly push it against clutch plate wth motor running and AC on at lowest temperature setting. If clutch plate kicks in and engages the compressor, them shimming is needed hold plate clearances within spects. I jacked up the right front, put in a safety jack stand,and working from underneath, I checked the clearance. It was 30 thousands over spects. With Simple Green and water ,I cleaned the clutch face and blew it dry. Working from underneath(which gives access to the clutch) and using a screwdriver to lift the existing spacing tabs, I inserted a small, bread bag tie clip size and thickness, shim under each tab and secured them in place with epoxy. Some use crazy glue. This is hold shims in place when clutch is not engaged. A recheck showed spect. clearance and the AC works perfectly. This may not be Mfg's recommendations; however, it worked for me and saved dismantling the clutch assembly.
would this work the same for a 2005 v50? The A/C cuts out intermittently. If I tap the compressor with a wrench it will start spinning again. Also can I do this on the vehicle, removing belts first of course.
Worked like a charm. Mine had 3 shims. I removed 2 and it is working great. I had to use a puller to remove it and the outside looked slightly different with 2 belt pulleys. Thanks for saving me hundreds of dollars!
Hey Jimboy, could you please tell me what type clutch puller you used and where you got it? I'm desperately trying to pry mine off today and it doesn't come off... I have 2004.5 T5 similarly than you... Thanks in advance!
My 2001 V70 compressor works flawlessly until today, when we hit 107. Now it kicks off and won't kick back on until the unit has had a few minutes to cool. Is this a shim issue or is the unit overheating, causing some safety device to disengage the clutch.
Thank you!
Thank you!
So, if overheating, how is this fixed. Shop service with coolant and oil change or something else? An A/C that doesn't work when it's hot out is kinda foolish. Thank you for the help.
worldbound4now
Those two treads may help you,
https://volvoforums.com/forum/volvo-850-16/newbie-c-question-31774/
https://volvoforums.com/forum/volvo-850-16/c-does-not-cool-good-when-hot-31761/
worldbound4now
https://volvoforums.com/forum/showthread.php?t=31774
https://volvoforums.com/forum/showthread.php?t=31761
More AC A/C Compressor, Low Sensor, High Sensor Pics at: https://volvoforums.com/forum/album.php?albumid=156
